dc to ac convertor, my pulses into sinusoidal wave
adnan_merter
Full Member level 3
The most beautiful city of the world
hey guys i need a circuit which converts dc 5v to ac 5v
i know other circuits with tranformators but i don't need to increase my voltage value i just need to convert my pulses into sinusoidal wave
it is important to control a ac motor's speed
thanx
dc to ac convertor
How much current do you need? Does it really need to be a sine wave? You may be able to use a square wave in which case it becomes a lot simpler.
Keith.
Re: dc to ac convertor
i am trying to design a speed control circuit for an ac motor. and the only way to control speed of an ac motor without losing torque is to control the frequency of the supply. it must be a sinusoidal wave ,motors can only work properly with sinus.
i don't need very high current, i am not gonna force the motor it will work on idle, max 1 Amp enough, but the higher voltage is the better.
Are you sure that is correct? There seem to be brushless 3 phase motor drives that use square waves.
Assuming you really do need a sine, have you considered a sine PWM drive? Is it a single phase motor?
Keith.
Keith.
Sorry i should have used the correct words, motors can be driven some kind of signal shapes but i am intended to use 3 phase brush-less inductive motor and it is better driven by sine waves ,and the other types you told are a little expensive i think
dc to ac convertor
just of the culf,
use a resistor ladder to drive a npn transistor to generate the sine wave, code could easily speed up or slow down your run up and down the resistor ladder
should be easy to find a 1 amp transistor
you need to do this with 3 ladders and keep the phase 120deg apart
