dc script about Ethernet MAC IP CORE
tavidu
Member level 1
Hi all,
I 'm designing ethernet mac IP CORE, which supports 1000M/100M/10M/TBI mode.
There are many clocks in my design. In deifferent mode, different clock is used, so I use several MUX for clock selection.
But I 'm not confident with my systhesis&STA script about clock MUX. Anyone can help me? or paste your synthesis script of MAC IP CORE.
kelvin_bao
Junior Member level 2
it seems difficulty.
in one of our company project,we also use mux to select clock by register value.but out clock no more than 150Mhz.
you design support 1Ghz,so fast speed.
cnspy
Full Member level 3
For synthesis, maybe you need to use the fastest clock to constrain your design.
For sta, maybe you need to write different script for each clock to pass the MUX.
You have to pay more attention on your design when switching the clock in flying
ami
Member level 3
VN
I have just finished a project like that. My experiences about this are:
1. with GE @1.25 MHz, you should use internal SERDES
2. You can not use a wide clock range on 1 port, because there is no SERDES that provide you such a wide clock range. You should devide your design into 2 port type: 1 for the 531.05MHz & 270MHz and 1 for 1.25GHz
3. For the 531.05MHz & 270MHz, in DC, set clock = 500; in STA, you can set the MUX to have 2 case analysis on each of these frequencies.
Hope ths help :)
xworld2008
Full Member level 4
I think this need a hard macro to receive data, in the ip don't need so fast , and the hard macro you need design and verify use spice , and the ip just need 1000M/8 or 1000M/16. by the way , the io of 1000M is very hard design.
