weeb0
Junior Member level 2
- Joined
- Jan 26, 2008
- Messages
- 21
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,472
Hello,
I have a little problem that I don't know how to fix, if fix is needed.
I have a small control board that control a motor, a pump and a linear device (like car electronic door unlock device). It can happen that the end user would turn the motor manually. When the motor is turned in reverse polarity, I have a schottky diode (flyback) that short the motor and everything is fine. When the motor is turned in the normal way, up to 12V 100mA is sent in my circuit and the card is powered on. I don't understand how this can happen since there is a mosfet that should closes the circuit.
I could add a diode to isolate the 12V but I would lose 0.6V and it is not something that I want.
Or I could think that there will have a 12V voltage on my board (unsure how this can occur) and it should not cause any harm to the board ? Maybe add a zener somewhere to be sure the voltage would not increase more than 16V
Any suggestion ?
Thank you
Any suggestion ?
Thank you
