robiwan
Junior Member level 2
Hi, I aim to build a 3-phase inverter (PWM) with output 3x230VAC (Y, 3x400VAC Delta), but I'm confused as to how calculate which DC link voltage is needed for the required outputs ?
TIA
/R
TIA
/R
Not sure what you mean by "balanced" but I'm planning to create the three phases with 3 half-bridges, I suppose this would be considered "non-balanced" ?You need a "balanced" sine modulation to get along with 560V, otherwise bus voltage must be 650V.
You need 3 legs to create 3 phase not 3 bridge.
DC link must be minim equal with peak of AC voltage, so for 230V ac you need DC link of 325Vdc. And if you want o create 3-phase balanced system, need also to keep 120degree phase shift. Some inverters use a chopper in DC link or a controlled rectifier to control output voltage at various load (current) to overcome voltage loses. In motor 3-phase inverter this voltage control is mandatory, to keep voltage/frequency aprox. constant on entire speed range.
Ah.. but therein lies my confusion, you've captured in nicely. The 564VDC would be correct if the line voltage was driven by two phases 180 degree apart, in essence like having a full bridge driven by 564VDC resulting in peak to peak voltage of 2 x 564 V = 400 VAC rms. But the phases are 120 degree apart so there will never be peak to peak voltage of 2 x 564 V. So I think the DC link voltage needs to be 2 x 230 * 1.41 = 650 VDC as suggested by FvM... :???:Yes, sure 3 half bridge; sorry...
Regarding voltage: if phase voltage = 230V, result line voltage = 400V; maxim inverter line voltage = DC link voltage, so you need that peak line voltage that is 400x1.41 = 564V = DC link voltage.
Now you arrived at the point I addressed in my posts.So I think the DC link voltage needs to be 2 x 230 * 1.41 = 650 VDC as suggested by FvM...
Ok, sorry for putting words in your mouth ;-)Now you arrived at the point I addressed in my posts.
I didn't suggest to use 650 V. I suggested to use balanced modulation to get along with 560 (or more exactly 565) V.
