hadigan
Newbie level 3
- Joined
- Feb 17, 2012
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,331
Hi guys, need help with some fundamentals.
I need to implement a DC-DC converter for battery "fast charging" application. The topology that will be used is the Full Bridge Phase Shifted with Diode rectifiers.
Some important details:
Input Voltage: 200 Vdc
Output Voltage: 15 Vdc
Output Current: 50 Amps minimum
All the recent journals that related to DC-DC converter use very high switching frequency (~100kHz) for the transistor switching signals, which requires high frequency transformer.
The problem is, the only transformers I can get that can support 50A minimum current is the 50 Hz transformer, which requires my switching signals to be 50 Hz. My questions are:
1) Is it academically incorrect to use 50 Hz switching frequency for my dc/dc converter?
2) Is there other advantages of using high frequency transformer other than its small size?
That is all, thanks in advance. Suggestions are most welcomed
