dc-dc converter - high efficiency, low noise and ripple
ksyfer
I need to design a 24V dc (input supply tolerance 19.2V to 32V dc) to 5V, 3A dc converter with 1.5KV isolation between the input and the output.
I want the dc-dc converter to have a high efficiency (90+ if possible) and low ripple (<200mVp-p) at the output
I don't want any software control over the converter i.e., I dont want the PWM switching to be controlled by a micro controller or a DSP.
I also want the converter to be closed loop i.e., control using feedback
Currently, I am using flyback configuration for this design.
Please suggest a better configuration for the design.
Any help is appreciated
Thanks in advance
A forward or push-pull converter would likely suit your needs. The ripple spec shouldn't be a problem, but the efficiency spec will require careful selection of the components, especially the transformer.
Reactions: ksyfer
    ksyfer
Thank you mtwieg
Any document / website with guidelines/rules of thumb for transformer selection?
I will try too, but advice of an experienced person will save my time...
