bharti thakur
Hi everyone,
I need to design and fabricate a power conditioning unit for a fuel cell system which consists of a converter, inverter and battery.
The system requirements are as follows:
The converter takes output from fuel cell in the range of 40-24 V dc which is the input for converter and the converter is to be designed to deliver a 24 V dc at its output which is fed to the inverter and the inverter gives 230 V ac at its output and the battery is to be recharged by the fuel cell.
I want to build this system using commercially available inverter and ic for converter as well as i want to develop a self designed converter and inverter because for other fuel cells i have do not generate a output which can be directly used with commercially available ics.
I being a fresher in electronics field dont have an idea of doing it.
Can anybody suggest me such ics?
