Register Log in
DC compiler error in the analyze log file
research235
Full Member level 6
DC compiler error
Dear all
I have some very basic error using design compiler. In the top level VHDL code library is defined. some thing like this
library ieee;
use IEEE.std_logic_1164.all;
use ieee.numeric_std.all;
library XXX;
use xxx.xxx.all;
I am trying to synthesis the Top level and using the following command include the library
define_design_lib "xxx"" -path ~/xxx
I have this error in the analyze log file.
[Error] xxx is not a primary unit of library xxx
any help is greatlt appreciated
best regard
Sig
amar.reddy402
Newbie level 2
Re: DC compiler error
hi,
This is the problem with work libraries. check the use-clause in your RTL. The libraries included using USE clause in a design should be analyzed before analyzing the design.
make sure parameters file and utilities files are analyzed in order.
Toggle Sidebar
