Hello,
I'm working on 12V->24V boost converter 36W max. I choose CC mode and current mode controller (UC3843).
I have problems / questions about the feedback loop:
Is current mode a good choice if the output current is not constant and changing from 10% to 80% of the maximum current ?
The shunt resistance in the transistor's source is set to produce 1V for the maximum current but if the output current is 10%, the controller is not working in current mode ? can the circuit still be stable ?
I also read that the boost CCM with current mode is difficult to stabilize because of RHP zero. What is your opinion and experience ?
Thank you
