elliot_cai
Hello!
I use write_lib command in Synthesis 2010 covert lib file to db file then input in Astro 2007, it's error input.
Then I use Synthesis 2007 covert the same lib file to db file, the Astro 2007 can recognize this file.
And the db files size are different, the 2007 version is bigger than 2010 version.
I wonder that if there are differet version type db files? How can I generate the old version db file in Synthesis 2010 which can be compatible with Astro 2007?
Thanks a lot!
Thanks a lot!
