datalogging sampling frequency bottleneck
Skyland
Junior Member level 3
My datalogging system which consits of the Flora, RTC, SD card breakout board, LSM9DS0 sensor is shown in the picture below;
The sampling rate/s is capped at 30 when writing into the sd card. If I disable the sensor and only save the time it goes up to 65. Writing into the serial interface rather than the sd card makes the rate goes up even higher at 127. for my application I need at least 100 samples/s. I am thinking the sd card is the problem after making the tests mentioned. The flora clock at 16Mhz is surely able to provide a higher sampling frequency. After checking the sensor datasheet and library I haven't found any limitation either. any input on this issue?
