Data Transfer over GPRS using Fastrack M1306B
derunningman
Newbie level 2
HI all,
since i'm new with digital communication, i wanna ask several questions
1. Is it possible to do data transfer with at command (via Hyper Terminal) using Fastrack M1306B? I only found how to set the GPRS properties with at command for that type of modem, not to transfer data (or even access some websites)
2. If it's not possible, what modem should i use for this type of communication, concerning for the low cost.
Thanx
HI all,
Thanx
Hello,
i m trying to do exactly the same, to send some data from terminal to tcp/ip socket and i have the same problem. I cannot find any commands to send data to tcp socket. Did you finally suceed on that?
Thanks in advance!
Hello,
Thanks in advance!
can't do with m1306b, it doesn't have tcp/ip stack. I've tried it using SIM300C, and it works.
Reactions: profitis
    V
    profitis
Thanks for your quick response!
At m1306b manual (page 2, gprs packet data features) it says "Embedded TCP/IP stack"... :S :S
Where did you find that M1306B doesnt have tcp/ip stack?
