bizoo
Member level 5
I am using simulink and i am using the sine wave generator from signal processing blockset,
i am using the frame based output and am trying to visualize the signal generated by brining it to workspace in a variable(vector ) and then plotting it (i may also use the vector scope but i prefer plotting it)
now my problem is that the signal is stored in the workspace in the third dimension of the variable
i am pretty bemused by that!
can any one tell me the reason for that? and also is there a nay way of changing this and saving the signal in either row or column format and not in third dimension?
One can build a custom block to do the shifting from this third dimension to 1st or 2nd, but i guess there will be a better way of doing it
br
br
