data sheet for zaz030
suma_ranga
Newbie level 5
Bangalore
hello all,
i need data sheet for zaz 030 finger print module. if anybody is having that please send me. its urgent. i could nt get that in net.
tpetar
Advanced Member level 5
Pancevo-Belgrade, Serbia
Sorry my friend only this specification :
Product Description:
ZAZ - 030 is a common fingerprint recognition module, using the most advanced RF-type fingerprint sensor,high-speed signal processor DSP, high performance fingerprint matching algorithms and other software and hardware.
Specifications:
Specifications Name: Value Fingerprint
Sensor: RF Principles of dermal fingerprint
Sensor detection capabilities: detection of leather with the ability to fingerprint
Capacity: 162 (may be increased to 930)
False Accept Rate (FAR): 0.008% (security level 3 pm)
False Reject Rate (FRR): 0.005% (security level is 3)
Average matching speed: 1 second
Matching: matching methods: (1:1)
Search methods: (1: N)
Characteristics of documents: 256 bytes
Template file: 512 bytes
Security level: 5 (from low to high: 1,2,3,4,5)
Antistatic ability: 15KV
High strength anti-wear: 1 million
Working Environment: Temperature: -20 ℃ - +65 ℃
Relative Humidity: 40% RH-85% RH (no condensation)
Storage Environment: Temperature: -40 ℃ - +85 ℃
Relative humidity: <85% H (without Gel )
Host computer interface: UART (TTL logic level) or USB1.1
Communication baud rate (UART): (9600 * N) bps where N = 1 ~ 12 (default value of N = 6, that is 51600bps)
Supply voltage: DC3.6 ~ 6.0V
Power supply current:
Operating current: 100mA (typical)
Peak Current: 150mA
Dimensions (L * W * H):
Split: Module: 30 * 22 * 1mm
Fingerprint sensor: 20 * 17mm
Features:
1, finger flexibility to adapt to the prevailing conditions, whether dry fingers, wet fingers, light texture fingerprints, old fingers and so have high recognition rate.
2, automatically end image acquisition, and image quality is getting better.
3, strong security fingerprint, fingerprint sensor, the recognition principle only to the human dermal skin reactions, a fundamental question to eliminate the artificial fingerprint
4, anti-static capability: from static electricity in dry areas Sao very suitable for easy
5, Wide Temperature Range: for especially cold or especially hot areas
6, slim volume: a variety of end products can be embedded into the main application areas: can be embedded in a variety of end products, such as: access control, attendance, safe, car door locks
suma_ranga
Newbie level 5
Bangalore
hey thank u so much.....
Specifications:
Peak Current: 150mA
Features:
