data required time in PT report timing
raviram80
Member level 3
This is urgent.
Can you please let me know how data required time is calculated in the report_timing command that comes at the end. I understand how data_arrival time is calculated.
I see
In the data_arrival time section I see
clock CLK' (rise edge) 800.00 800.00
clock network delay (propagated) 3503.00 * 4303.00
In the data_required section I see the following
clock network delay (propagated) 5111.00 * 5911.00
How is this clock network delay calculated and how is this different from clock network delay in the data arrival time section
I also see clock reconvergence pessimism and clock uncertainity as well.
Please reply at the earliest.
Regards,
Ravi
raju3295
Full Member level 4
hi ravi,
looking at ur report,
both clocks are starting at the same time, that means this is for hold analysis, and the delay for capture clock is more so my guess is correct.
both propoaged delays will be diff, as for launch path tool will take the shortest path and for the capture path it will take the longer path, so the delays will be different,
usually opposite for setup analysis.
shelby
Full Member level 2
add the option "-path full_clock_expanded" to your "report_timing" command. You will see the full clock paths going to both launch and capture endpoints.
