data pointing in ROM in pic16f887 problem.
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi all,
i work in assembly language with pic16f887
i want to use ROM as readable memory.
like i have used with DPTR in 8051.
what are DB and DT in PIC16?
how can i use ROM with DB or DT direactive for making long lookup table?
DB = "Define Byte"
DW = "Define Word"
DT = "Define Table"
DE = "Define EEPROM"
They are all instructions to allow you to directly store data in memory. See the document "MPASM_MPLINK_User_Guide.pdf" for more information, it should be in your compiler folder. The example it gives is:
#include p16f877a.inc     ;Include standard header file for the selected device.
org 0x2100     ;The absolue address 2100h is mapped to the 0000 location of EE data memory.
;You can create a data or character table starting from any address in EE data memory.
ch_tbl2 de "PICmicro"    ;8 EE data memory locations (starting from 0) will be filled with 8 ASCII characters.
end
but check the address 0x2100 because it is different from one processor to another. It isn't a real address, the programmer sees it as a special location and puts it in EEPROM instead of normal program memory. The example is for the 16F877A.
Brian.
I just want to use ROM as constant data as it is done in 8051 with DPTR.
i will define word or data and i will read it.
the question is, how i can read that data or word?
as i define like this
org 100h
db "hello"
it is written in memory but please tell the routine in which i will read it and may be display it. I just want this data in W reg one by one.
I can do it with
addwf pcl,f
retlw 'h'
retlw 'h'
retlw 'e'
retlw 'l'
retlw 'l'
retlw 'o'
retlw 'w'
retlw 0x00
but it is lengthy and time consuming
The easiest method is to write it as:
DT "hello"
Then access it using the "addwf pcl,f" method but you do not have to put all the individual retlw instructions in place. Like this:
addwf pcl,f
DT "hellow",0
You can also access it using the FSR register as a pointer to the table. I'm rusty at 8051 code but I think FSR is similar to DPTR in PIC language.
PIC18 devices and some enhanced PIC16 devices have dedicated table writing and reading instructions but they are not present in the 16F887A
Brian.
