Data Logging on Pen Drive
garg29
Advanced Member level 1
This may be a difficult project to think about for me, at present, but still hope so. I want to read a physical parameter continously & save the values in Pen drive, everytime after a particular time delay. I'm somewhat familiar with PIC18F4550 USB Coding but it's still not having USB 'HOST'. So which controller do you guys suggest to start with for this kind of project.
Thanks a lot,
With best regards,
Garg
Can you use USB Device Controller?
The question is repeating every few months, I think. Yes, you need a host controller to connect a mass-storage device, e.g. an USB pen.
A PIC24FJ256GB works perfectly with the ready-to-use Microchip C30 example projects. Also other embedded host solutions, e.g. a
FTDI Vinculum or Atmel at90usb128 can be used.
    garg29
Thanks a lot. I'll start working on this now.
this is not very difficult... if you use i2c , module ,and then read write data on the pen drive then ,your problem is being solved.
Except the Pen Drive is USB not I2C
FvM is very correct and pointed very practical and smarrt idea.
To use a example. from microchip.
I beaeve all you need to do is to change modulation part of recordable signal source.
I wish you all the best...
If it is not too busy PM progress.
Added after 16 minutes:
I quess he ment i2c to USB module. ... somekind expensive IC that makes things so much easier.
