.... I realize that there is USB module on the PIC18F2550 which means that USB controller is present on the PIC18F2550, right ?. Does this means that I can directly connect the USB cable to the PIC pins D+, D-, GND ? after programming.
* Project name:
original : HID_Read_Write_Interrupt (Testing the USB HID connection)
revised by paulfjujo
* Copyright:
(c) Mikroelektronika, 2011.
* Revision History:
20110929 initial release (FJ);
* Description:
This example establishes connection with the HID terminal that is active
on the PC. Upon connection establishment, the HID Device Name will appear
in the respective window. After that software will wait for data and
it will return received data back.
* Test configuration:
MCU: PIC18F2550
dev.board: StartUSB Board 18F2550
Oscillator: HS, 8.000 MHz (USB osc. is raised with PLL to 48.000MHz)
Ext. Modules: None.
SW: mikroC PRO for PIC 6.50
* NOTES:
(*) Be VERY careful about the configuration flags for the 18F2550 - there's
so much place for mistake!
#define CLS 12
#define BS 8
#define TAB 9
#define CR 13
#define LF 10
#define Bell 7
#define ON 0 // logique inverse avec led tiree au +5V
#define OFF 1
#define Nb_Count1 24 // 24 * 41.666mS = 1 seconde (init timer1 à 3035 et prescaler=1/8)
sbit LED_Sup at LATA1_bit; // led rouge
sbit LED_Inf at LATB3_bit; // led jaune J2 enlevé et strap entre RB3 et LED3 verte
unsigned char readbuff[64] absolute 0x500; // Buffers should be in USB RAM, please consult datasheet
unsigned char writebuff[64] absolute 0x540;
const unsigned int USB_VENDOR_ID = 0x1234;
const unsigned int USB_PRODUCT_ID = 0x1234;
const char USB_SELF_POWER = 0xC0; // Self powered 0xC0, 0x80 bus powered
const char USB_MAX_POWER = 50; // Bus power required in units of 2 mA
const char HID_INPUT_REPORT_BYTES = 63;
const char HID_OUTPUT_REPORT_BYTES = 63;
const char USB_TRANSFER_TYPE = 0x03; //0x03 Interrupt
const char EP_IN_INTERVAL = 1;
const char EP_OUT_INTERVAL = 1;
const char USB_INTERRUPT = 1;
const char USB_HID_EP = 1;
const char USB_HID_RPT_SIZE = 57;
/* Device Descriptor */
const struct {
char bLength; // bLength - Descriptor size in bytes (12h)
char bDescriptorType; // bDescriptorType - The constant DEVICE (01h)
unsigned int bcdUSB; // bcdUSB - USB specification release number (BCD)
char bDeviceClass; // bDeviceClass - Class Code
char bDeviceSubClass; // bDeviceSubClass - Subclass code
char bDeviceProtocol; // bDeviceProtocol - Protocol code
char bMaxPacketSize0; // bMaxPacketSize0 - Maximum packet size for endpoint 0
unsigned int idVendor; // idVendor - Vendor ID
unsigned int idProduct; // idProduct - Product ID
unsigned int bcdDevice; // bcdDevice - Device release number (BCD)
char iManufacturer; // iManufacturer - Index of string descriptor for the manufacturer
char iProduct; // iProduct - Index of string descriptor for the product.
char iSerialNumber; // iSerialNumber - Index of string descriptor for the serial number.
char bNumConfigurations; // bNumConfigurations - Number of possible configurations
} device_dsc = {
0x12, // bLength
0x01, // bDescriptorType
0x0200, // bcdUSB
0x00, // bDeviceClass
0x00, // bDeviceSubClass
0x00, // bDeviceProtocol
8, // bMaxPacketSize0
USB_VENDOR_ID, // idVendor
USB_PRODUCT_ID, // idProduct
0x0001, // bcdDevice
0x01, // iManufacturer
0x02, // iProduct
0x03, // iSerialNumber
0x01 // bNumConfigurations
/* Configuration 1 Descriptor */
const char configDescriptor1[]= {
// Configuration Descriptor
0x09, // bLength - Descriptor size in bytes
0x02, // bDescriptorType - The constant CONFIGURATION (02h)
0x29,0x00, // wTotalLength - The number of bytes in the configuration descriptor and all of its subordinate descriptors
1, // bNumInterfaces - Number of interfaces in the configuration
1, // bConfigurationValue - Identifier for Set Configuration and Get Configuration requests
0, // iConfiguration - Index of string descriptor for the configuration
USB_SELF_POWER, // bmAttributes - Self/bus power and remote wakeup settings
USB_MAX_POWER, // bMaxPower - Bus power required in units of 2 mA
// Interface Descriptor
0x09, // bLength - Descriptor size in bytes (09h)
0x04, // bDescriptorType - The constant Interface (04h)
0, // bInterfaceNumber - Number identifying this interface
0, // bAlternateSetting - A number that identifies a descriptor with alternate settings for this bInterfaceNumber.
2, // bNumEndpoint - Number of endpoints supported not counting endpoint zero
0x03, // bInterfaceClass - Class code
0, // bInterfaceSubclass - Subclass code
0, // bInterfaceProtocol - Protocol code
0, // iInterface - Interface string index
// HID Class-Specific Descriptor
0x09, // bLength - Descriptor size in bytes.
0x21, // bDescriptorType - This descriptor's type: 21h to indicate the HID class.
0x01,0x01, // bcdHID - HID specification release number (BCD).
0x00, // bCountryCode - Numeric expression identifying the country for localized hardware (BCD) or 00h.
1, // bNumDescriptors - Number of subordinate report and physical descriptors.
0x22, // bDescriptorType - The type of a class-specific descriptor that follows
USB_HID_RPT_SIZE,0x00, // wDescriptorLength - Total length of the descriptor identified above.
// Endpoint Descriptor
0x07, // bLength - Descriptor size in bytes (07h)
0x05, // bDescriptorType - The constant Endpoint (05h)
USB_HID_EP | 0x80, // bEndpointAddress - Endpoint number and direction
USB_TRANSFER_TYPE, // bmAttributes - Transfer type and supplementary information
0x40,0x00, // wMaxPacketSize - Maximum packet size supported
EP_IN_INTERVAL, // bInterval - Service interval or NAK rate
USB_HID_EP, // bEndpointAddress - Endpoint number and direction
EP_OUT_INTERVAL // bInterval - Service interval or NAK rate
const struct
char report[USB_HID_RPT_SIZE];
hid_rpt_desc =
{0x06, 0x00, 0xFF, // Usage Page = 0xFF00 (Vendor Defined Page 1)
0x09, 0x01, // Usage (Vendor Usage 1)
0xA1, 0x01, // Collection (Application)
0x85, 0x01, // Report ID=1 (This is a global variable)
0x15, 0x00, // Logical Minimum (data bytes in the report may have minimum value = 0. This is a global variable)
0x26, 0xFF, 0x00, // Logical Maximum (data bytes in the report may have maximum value = 256. This is a global variable)
// Input report(ID=1)
0x19, 0x01, // Usage Minimum
0x29, 0xFF, // Usage Maximum
0x75, 0x08, // Report Size: 8-bit field size
0x95, 0x3F, // Report Count (63 + 1 byte for the report ID)
0x81, 0x02, // Input (Data, Var, Abs)
// Output report(ID=1)
0x91, 0x02, // Output (Data, Var, Abs)
0x85, 0x02, // Report ID=1 (This is a global variable)
// Input report(ID=2)
0x29, 0x08, // Usage Maximum
0x95, 0x01, // Report Count (1 byte + 1 byte for the report ID)
// Output report(ID=2)
0xC0}, // End Collection
//Language code string descriptor
const struct {
char bLength;
char bDscType;
unsigned int string[1];
} strd1 = {
4,
0x03,
{0x0409}
//Manufacturer string descriptor
const struct{
char bLength;
char bDscType;
unsigned int string[10];
}strd2={
22, //size of this descriptor string
0x03,
{'p','a','u','l','f','j','u','j','o',' '}
//Product string descriptor
const struct{
char bLength;
char bDscType;
}strd3={
0x03,
{'P','I','C','1','8','F','2','5','5','0'}
//Serial Number descriptor
const struct{
char bLength;
char bDscType;
unsigned int string[6];
}strd4 = {
14, //size of this descriptor string
0x03,
{'A','B','C','1','2','3'} // Count as two bytes
//Array of configuration descriptors
const char* USB_config_dsc_ptr[1];
//Array of string descriptors
const char* USB_string_dsc_ptr[3];
const code char mesg0[]="MikroC Pro V6.50 ";
const code char mesg1[]="HID Terminal USB PC ";
const code char * Messages[]={mesg0,mesg1};
unsigned char TEXTE[64];
unsigned char * txt;
unsigned char addr;
char * PtR;
char * PtE;
char cnt;
char kk;
unsigned int i,j,k;
char CRam1[20];
unsigned int EAH,EAL,EA0;
float ff1;
int FDC_Mini; // issu du potar de recopie ADC value <20
int FDC_Maxi; // issu du potar de recopie ADC value > 1000
int Etat;
volatile unsigned int Count1;
volatile int Flag_Timer1;
unsigned char sec;
unsigned int Toggle;
void USB_Init_Desc();
void strConstRamCpy(unsigned char *dest, const code char *source) ;
void interrupt(){
USB_Interrupt_Proc(); // USB servicing is done inside the interrupt
void Interrupts() iv 0x0018 ics ICS_AUTO
// ------ timer 1 ----------------
if ( (TMR1IE_bit==1) && ( TMR1IF_bit==1))
{ // Test "Peripheral Interrupt Request Register 1" for Timer1 Flag
Count1++;
if (Count1>=Nb_Count1)
Count1=0;
Flag_Timer1=1;
TMR1IE_bit=0;
// 24 * 41.666mS = 1 seconde et init timer1 à 3035 et prescaler=1/8 at 48MHz
TMR1H= 0x0B; // Hi (3035);
TMR1L= 0xDB; // Lo (3035);
PIR1.TMR1IF=0;
void USB_Init_Desc(){
USB_config_dsc_ptr[0] = &configDescriptor1;
USB_string_dsc_ptr[0] = (const char*)&strd1;
USB_string_dsc_ptr[1] = (const char*)&strd2;
USB_string_dsc_ptr[2] = (const char*)&strd3;
USB_string_dsc_ptr[3] = (const char*)&strd4;
void Init_Timer1(void)
T1CON=0;
T1CKPS1_bit=1; //prescal select=11 => 1/8
T1CKPS0_bit=1;
// T1GCON=0;
TMR1H= 0x0B; // Hi (3035); // 41mS at 49MHZ
// TMR1H= NbCycles_T1>>8;
// TMR1L= NbCycles_T1 & 0x00FF;
Count1=0;
Flag_Timer1=0;
PIR1.TMR1IF=0; // Reset Timer1 Flag
PIE1.TMR1IE=0; //Disable interrupt TMR1
IPR1.TMR1IP=0; // disable High level interrupt
INTCON.PEIE=0; // disable peripheral interrupt
TMR1ON_bit=0; // timer1 OFF
void Float2Ascii (float x, unsigned char *str,char precision)
/* converts a floating point number to an ascii string */
/* x is stored into str, which should be at least 30 chars long */
int ie, i, k, ndig;
double y;
ndig = ( precision<=0) ? 7 : (precision > 22 ? 23 : precision+1);
ie = 0;
/* if x negative, write minus and reverse */
if ( x < 0)
*str++ = '-';
x = -x;
/* put x in range 1 <= x < 10 */
if (x > 0.0) while (x < 1.0)
x *= 10.0; // a la place de =*
ie--;
while (x >= 10.0)
x = x/10.0;
ie++;
// in f format, number of digits is related to size
ndig += ie; // a la place de =+
//round. x is between 1 and 10 and ndig will be printed to
// right of decimal point so rounding is ...
for (y = i = 1; i < ndig; i++)
y = y/10.;
x += y/2.;
if (x >= 10.0) {x = 1.0; ie++;}
if (ie<0)
*str++ = '0'; *str++ = '.';
if (ndig < 0) ie = ie-ndig;
for (i = -1; i > ie; i--) *str++ = '0';
for (i=0; i < ndig; i++)
k = x;
*str++ = k + '0';
if (i == ie ) *str++ = '.';
x -= (y=k);
x *= 10.0;
*str = '\0';
void Init_ADC()
ADCON0 = 0x00;// select channel 0 (AN0)
ADCON1 = 0;
ADCON2 = 0;
ADCON1.VCFG1=0; // VREF- = VSS=0V
ADCON1.VCFG0=0; // VREF+ = VDD=+5V
ADCON1.PCFG3=1;
ADCON1.PCFG2=1;
ADCON1.PCFG1=1;
ADCON1.PCFG0=0;
ADCON0.ADON = 1;//Enable A/D module
//ADCON2 setup: Right justified, Tacq=16Tad, Tad=2*Tosc (or Fosc/2)
ADCON2.ADFM=1; // right justified
ADCON2.ACQT2=1; // 111 => 20 Tad
ADCON2.ACQT1=1;
ADCON2.ACQT0=1;
ADCON2.ADCS2=1; // FOSC /64
ADCON2.ADCS1=1;
ADCON2.ADCS0=1;
void Read_ADC0()
ADCON0.CHS0=0; // Channel 0 (AN0) Position du potar rectiligne
Delay_ms(1);
ADCON0.GO_DONE = 1;//Start A/D Conversion
while(ADCON0.GO_DONE ==1);//Loop here until A/D conversion completes
EA0=(ADRESH <<8) + ADRESL;
// --- Copie le texte depuis ROM vers RAM
void strConstRamCpy(unsigned char *dest, const code char *source) {
while (*source)*dest++ = *source++ ;
*dest = 0 ; // terminateur
void main(void)
PORTA=0;
TRISA0_bit=1; // Ana input EA0
TRISA1_bit=0; // output to led verte (cablée sur la carte StartUSB )
TRISB0_bit=1; // must be configure as input for I2C
TRISB1_bit=1; // must be configure as input for I2C
TRISB3_bit=0; // output to led rouge externe
CMCON = 0x07; // Disable comparators
Delay_ms(150); // wait for a while to oscillator stabilizes
LED_Sup=0;
LED_Inf=0;
Toggle=0;
Init_ADC(); // select channel 0 (AN0)
Delay_ms(100);
txt=&TEXTE[0];
HID_Enable(&readbuff,&writebuff); // Enable HID communication
Init_Timer1();
Flag_Timer1=0;
TMR1IE_bit=1;
TMR1ON_bit=1;
PEIE_bit=1;
GIE_bit=1;
sprintf( &writebuff," Timer1 initialisé et Armé \r\n");
// rajout test timer1 pour ne pas etre bloqué
// si on a pas activé le terminal HID : USB HID Libray
while((Flag_Timer1==0)&& (!HID_Write(&writebuff,64)) );
while(1)
while(!HID_Read() && (Flag_Timer1==0)); // wait for data on USB
if(Flag_Timer1==1)
Flag_Timer1=0;
Count1=0;
TMR1IE_bit=1;
Read_ADC0(); // result into EA0
ff1=(float)EA0 * 5.00 /1024.0;
Float2Ascii (ff1, CRam1,2);
if (Toggle==1)
sprintf( &writebuff," ADC=% 5u %04X soit %s Volts \r\n",EA0,EA0,CRam1);
while(!HID_Write(&writebuff,64));
else
if(strncmp(&readbuff,"RED_ON",6)==0 ) LED_Sup=1;
if(strncmp(&readbuff,"RED_OFF",7)==0 ) LED_Sup=0;
if(strncmp(&readbuff,"GREEN_ON",8)==0) LED_Inf=1;
if(strncmp(&readbuff,"GREEN_OFF",9)==0) LED_Inf=0;
if(strncmp(&readbuff,"TOGGLE",6)==0) Toggle= Toggle ^ 0x0001;
if (strncmp(&readbuff,"ADC",3)==0)
if (EA0 >800)
LED_Sup=1;
if (EA0 <100)
LED_Inf=1;
Delay_ms(500);
