ansonyeap
Member level 2
Hi All,
Currently I need to work on DAC which can produce 2 output voltage at the same time i.e Normal output voltage and another one is inverted output voltage of the 1st one.
My design for the DAC is a R2R type with normal output voltage from 0(CODE0) ~ 5V(CODEFULL). I need to produce another inverted output voltage from 5V(CODE0) ~ 0V(CODEFULL).
Can anyone suggestion idea on how to be able to do this?
is there any buffer topology can able to do this?
thank you in advance.
