The DACs has two kind of non-linearity. The integral (INL) which is a dispersion of measured value from an "ideal" one. This "ideal" transfer curve (Vout vs DAC code) is the straight line connecting the first and the last points of measured values (so called "end-point" method), while INL values are calculated as
\[INL_k=\frac{V_{meas}(k)-V_{ideal}(k)}{LSB}\]
where:
k - DAC code (natural number in a range of 0 to 2^N-1, N is a resolution
V_meas(k) is a measured output voltage (or current) for k-th code
V_ideal(k) is an ideal value for k-th code. This function is defined as \[V_{ideal}(k) = \frac{V_{meas}(2^N-1)-V_{meas}(0)}{2^N-1} k+V_{meas}(0)\]
LSB is a step value (slope of ideal line)
The "best fit" method is not recommended because lowering the non-linearity values.
The second kind of non-linearity is a dispersion of actual step value from a LSB and is defined as:
\[DNL_k = \frac{V_{meas}(k+1) - V_{meas}(k)}{LSB}-1\]
This parameter inform about monotonicity of converter.
