flashload lite ver.5.0
I think if you use ribbon/flat cable type 25PIN D-type and 26PIN header will solve your problem see the picture of the programmer at dilogic.
Note: If you punch a flat/robbon cable on the 25-PIN D-Type connector (that support ribbon/flat cable direct) and match the Pins of the connector to the wire it will be like 1,14,2,15,3,16,4,17........... where as if you punch a ribbon/flat cable to a 26-Pin header you will get 1,2,3,4,5,6,7.....
I think this will clear you very much.
