CVAVR coding problem with ATmega 8535
wakaka
Full Member level 4
Hi there, I'm doing a simple test using CVAVR with ATEMGA8535, and i dun get the expected result.
I only wan push button once, running LED start, push again, stop.
The problem is the push buttom seems not sensitive.
1st time press the push button, LED starts running.
2nd pressed, it might or might stop.
3rd, 4th ,5th ..... pressed and so on, not responding sometimes.....
#include <mega8535.h>
#include <delay.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
unsigned char count, pstat;
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
// State7=T State6=P State5=T State4=T State3=T State2=T State1=T State0=T
PORTD=0x40;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
count=0x01;
pstat=0;
while (1)
      // Place your code here
if(!PIND.6)
{pstat = !pstat;}
if((PIND.6) &&(pstat==1))
 PORTC = count;
 count = count<<1;
 delay_ms(250);
 if(count==0)
{count = 0x01;}
if((PIND.6) && (pstat==0))
PORTC = 0;
member_tdh
Member level 5
Re: CVAVR coding problem
Hi!
You can try this code:
unsigned char mode=0;
DDRD=0x00;
PORTD.6=1;
while(1)
if(PIND.6==0)
while(PIND.6==0) {};
delay_ms(30);
if(++mode>2) mode=1;
if(mode==1) Led=ON;
else Led=OFF;
//else if(mode==2) Led=OFF;
:D
wakaka
Full Member level 4
thanks for ur suggestion, I'll try it out.
But wat i wanna know is that, did i write the code wrongly?? i dun think I'm wrong actually
artem
Turkey
	for(;;)
		// Wait for button press
		while(PIND.6 !=0)
		// Button is pressed so wait debounce time
		delay_ms(30);
		// After debouncing time has left check whether button is still pressed
		if(PIND.6 != 0)
			continue;
		// Button was pressed and kept for more than 30 milliseconds - play with your LED
		// here
		// Now after led has been handled wait for button release
		for(;;)
			while(PIND.6 !=1)
			// Button release detected - debounce button release
			delay_ms(30);
			if(PIND.6 == 1)
				break;
