[SOLVED] Cut points and cut nets in formality
nawaz.mjcet
Newbie level 6
Hi all,
what are cut points and cut nets in formality,why does a tools inserts cut points(not user defined) in netlist i,e implementation design.does this cut points will cause a verification failure ,if so what setup modification is to be done to pass the verification.
Thanks in advance.
Regards,
-Nawaz.
Did you mean automatic cut-point insertion by the tool, not by the User?
Which tool you are using?
Regards,
Pardeep
