Custom IP core with fixed point
adam_lo
Newbie level 6
Newbie level 6
I wanted to create IPCore to add two fixed point .
I added fixed_pkg file to pcores\add_fix_v1_00_a\hdl\vhdl .
first I wrote in entity :
port(
reg_out : out sfixed(29 downto -2);
and in architecture I wrote process
fix: process(slv_reg0,slv_reg1)
variable reg0,reg1,reg2 : (29 downto -2);
begin
reg0:=to_sfixed(slv_reg0,C_SLV_DWIDTH);
reg1:=to_sfixed(slv_reg1,C_SLV_DWIDTH);
reg2:=reg1 + reg0;
reg_out <=reg2;
end process fix;
when I wanted to import it
Errors:
D:\Labs\ipcore\pcores\add_fix_v1_00_a\hdl\vhdl\user_logic.vhd" line 151.
to_sfixed can not have such operands in this context.
D:\Labs\ipcore\pcores\add_fix_v1_00_a\hdl\vhdl\user_logic.vhd" line 152.
EDK:2121-Parse Errors encountered in HDL source
Warning:EDK:3590- Unable to detect temporary project file.
what are the steps to overcome this errors ?
Thanks in advance
<snip>
Thanks in advance
- Start by reading the user's guide.
- Then read the parameter types for the 'to_sfixed' function that you are calling and make sure that you are passing in the correct types
I'm assuming that your 'slv_*' signals are std_logic_vectors which implies that you have not done either of the above two points since std_logic_vectors have no numeric interpretation (unlike signed, unsigned, sfixed, ufixed, etc.)
Kevin
