current sensing technique for boost
hi_tech
Newbie level 6
current sensing boost converter
hi can any body help me
current sensing technique for boost = typically a resistor
A professor from HK univ wrote a paper about current sense in DC/DC, using switching mos to reduce power instead of resistor, you can refer to it.
just curious, why not mirroring?
If cost permits you can use mirror / Hall element etc
I was basically referring to the usual technique in today's low and medium power boost (e. g. PFC) and flyback (e. g. isolating off-mains) SMPS. As a matter of fact, they mainly use current sense resistors.
Obviously other techniques are available as well. Current sensing by MOS Rds,on is an interesting alternative particularly for low voltage synchronous buck regulators. It has to consider parameter variations and Rds,on TC, however.
Hall sensors are good for power electronics beyond several 10 A.
I don't yet understand, how a current mirror could have a meaningful application in this regard. Can anyone suggest a principle circuit?
Current Mirror is usefull when high side current sensing is required.
Added after 7 minutes:
current mirror may require a sense resistor in addition you can also refer
few patents e.g. US5262713
Added after 8 minutes:
An application note from Zetex
O.K., I see. I regarded this technique as resistor sensing as well.
High-side current sensing is mainly used with buck converters. I assumed (in silence), that the boost switch current shall be sensed, so there's no need for a current-mirror level-converter. High-side current sensing may be needed however, if the total input current is the interesting measurement, e. g. for a PFC boost converter.
