Current sensing amplifier
sivamit
Full Member level 4
hi,
i want to design a current to voltage converter circuit which should measure 1-25uA current using op-amps.The output of the amplifier will be given to an ADC to get equivalent digi value.
can anyone help me to design the circuit.:|
Please help!!
Check attachment there is some circuit for to read nA to mA.
By igo 64
For this current range you can consider amplifiers which are used to convert very small currents (-50pA to -50µA) from photo-detectors . In the following example the author employed an opamp from MAXIM, the MAX420, but there are other precision opamps, AD797, MAX427, LT1028, OP177 to name just a few, which can be used in this application ..
Regards,
IanP
