current mirror voltage drop
flabbergastt
Junior Member level 2
What is the best way to reduce the voltage drop of a MOSFET current mirror for both nMOS and pMOS? Would it be the same for a cascode current mirror or wide-swing current mirror?
thanks
crutschow
Advanced Member level 6
Colorado USA Zulu -7
You are generally limited by the gate-source threshold voltage (Vgs(th)) so you want transistors that have a low threshold.
kemiyun
Full Member level 4
Full Member level 4
I don't completely object to this but I don't completely agree either. Yes Vth is important but in ideal case you'd be able to go beyond gate voltage by Vth (assuming you don't care about accuracy that much). I think the ultimate limit is how much you can reduce the overdrive voltage, I believe this is a more generalized statement. But I'm not sure if this is what he meant with voltage drop.
