Thota Suresh Avionics
Member level 2
- Joined
- Jul 15, 2013
- Messages
- 45
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 8
- Activity points
- 345
I am measuring current through 5 Amps CT,which can measure maximum of 5-Amps, I don't know the number of turns in CT.
I have tried different shunt values to get 1 Volt at maximum CT rating and i have used 860E shunt value , i could find 0.96 V at 5-Amps load on CT.
I am reading 0.96V at 5 amps load through micro controller after removing 2.5V DC offset to applying TRMS algorithm. After I have derived a constant value 'X' and when it is multiplied with TRMS value i could find current proportional to the load and parllely observed with clamp meter.
X = Load in Current / Current in Voltage i.e., X = 5-Amps / 0.96 V =5.1867
the circuit which i have used is attached, is this the correct method to measure the current ? Do we have any better circuits and algorithms?
Rs = 860E
Rs = 860E
