jay1691
Member level 2
I have a Current Transformer for 10Arms rating with 1:1500 turns ratio. I'm not familiar with it. In Current transformers the specifications will be in primary current to secondary current ratio, but here the ratio is in terms of primary & secondary turns ratio.
1. How to calculate the current ratio from turns ratio?
2. Is it 10 Amps differ from 10Arms?
Please some one provide a good signal conditioning circuit for the current measurement. The datasheet is also attached.
Thanks in advance...
I have Found below method. is it corect ??
:1500 is the turns ratio.10 Amps = 10A
See the equation
Np/Ns=Is/Ip
Ip =10 A(considered max)
Is = ?
Np =1 turn(cable through the hole)
Ns = 1500turns
Is=(Np/Ns)Ip
Is =0.0066A
Burden resistance 75E
Out put voltage when 10A flowing through primary is 0.0066A*75E= 0.5V
Here my test Set up is below, Let me know if anything is wrong.
See the equation
Np/Ns=Is/Ip
Is = ?
Ns = 1500turns
Is=(Np/Ns)Ip
Is =0.0066A
