chikaofili
Junior Member level 3
Regulating current supplied / Current limitier
Hello,
I have an input voltage range of 0-1.8V
I need to design a circuit that at 0.9v The current is 300uA
but at 0 or 1.8V the current is 600uA
So basically
0 - 0.9 the current should decrease from 600uA to 300uA
0.9- 1.8V the current should increase from 300uA to 600uA
I tried to use using two current 'sources (mosfets)' each 300uA and pass transistor but I dont know if I am not biasing the pass transistors properly. because it didnt work
Any other idea or suggestions will be greatly appreciated.
Hello,
So basically
