I simulate a bipolar circuit with eldo, and I find a very strange problem: when power supply rise from 0(0ms) to 10V(50ms), from the operating point, I found the current flow out a path didn't equal the current flow in the same path, because some current flow through the substrate, but the substrate is reverse biasing, why?
Could some experts help me?
Your frontend schematic entry could have hidden nodes (substrate). It is in most design-kits an either explicite terminal, a text string or a nonaccessable hidden terminal. If you haven such hidden substrate terminal and you do not connect it back to your testbench circuit ground you can get backbias effects.
