In general, one can say that current feedack amps are faster (although there are voltage feedback amps on the market with a current feedback architecture and with the same speed).
The reason is that CFA´s must NOT be universal compensated. Nevertheless, they can be operated with each resistive divider in the feedback path, provided the resistor between output and neg. input is larger than a minimum specified value (in the region of 500 ohms...1kohm). Therefore, pure capacitive feedback as in integrating circuits is NOT allowed.
