CT ratio setting on energy meter
bobdxcool
Member level 5
Current Transfomer (CT) ratio setting on energy meter
I am using a smart energy meter which allows me to set the CT ratio among other parameters. I am using 50/5 ratio AC CT's. For the meter to do the kwh calculation correctly, I believe I have to set primary CT ratio to 50 and secondary CT ratio to 5. Now, if I have two rounds of the same 120 volt wire passing through the same CT, then I would set secondary ratio to 100. My question is, will this be equivalent to have just one round of wire through the CT and the primary ratio set to 50 , i.e the kwh calculated by the meter will still be right and I would'nt have to do any manipulations on the values obtained from the meter.
Meter data sheet:**broken link removed**
FvM
Super Moderator
Staff member
Bochum, Germany
No, you get range of 25 A with two primary turns.
schmitt trigger
Advanced Member level 5
The explanation is in the name: Ratio.
Ratio of primary turns vs secondary turns. Since CTs are usually a single primary turn, a 50:5 =10 current ratio means that the secondary must be 10 turns to maintain the same ratio. or 10:1, in the number of turns.
If now you put two turns in the primary while keeping the same 10 secondary turns, your new ratio will be 10:2 = 5; half of what you used to have.
The transformation ratio will change accordingly, such that to obtain 5 amps secondary, your primary can only be 25 amps.
Basic transformer equations. Remember the current transformation ratio is the reciprocal of the turns ratio.
