elec-eng
Full Member level 5
- Joined
- Nov 16, 2006
- Messages
- 243
- Helped
- 20
- Reputation
- 40
- Reaction score
- 5
- Trophy points
- 1,298
- Activity points
- 2,927
Dear all,
I am designing a simple slot antenna (just a rectangular cut in the ground plane) at 75GHz on a thick Si substrate . The slot has a length of 740um and a width of 22um as shown in next figure
for a small ground plane (1500 x 1500 um), the radiation pattern is perfect. It resembles that of a dipole but radiates strongly in the substrate side, as shown
However, when I increase the size of the ground plane and the substrate to 3000 x 3000 um, the radiation pattern becomes worse, as shown
The pattern keeps becoming worse when I increase the dimension of the ground plane and the substrate. Shown is the pattern for 5000 x 5000 um substrate
For 7000 x 7000 um, it is even worse:
And when I increase the thickness of the substrate to 4000 um to make it as if it is infinite, I get the following beam shape
S and Z parameters are the same for all cases.
I don't think it is a meshing problem because I mesh the critical regions very well. I also used Adaptive meshing and increased the simulation upper frequency but no use.
Having a large ground plane is important because finally I will design an array out of this slot.
Regards
Regards
