I'd like to know whether there's a way to transfer an object from one model to another.
For examle: one .mod file contains the antenna model and the other file contains the ground model. I want to create a third file containing both antenna and ground .
MWS stores the list of operations you make, such as drawing objects and assigning materials, as a simple text file. Just try to open the .mod file with notepad. Using a text editor like notepad you can easily copy and paste operations between projects. Just dont forget to do a structure update when you open the projet file with MWS after you ve done the editing with notepad.
Hope this helps
One of the most easy ways that I have used is to open the history list and mark all commands that I was interested in, and then create a macro from them (there's a button for creating macros in the history-list dialog)...
You can use the macro from any other MWS project to reproduce the geometry that you want...
