CST MWS vba script parameter sweep ASCII export
marcel1709
Newbie level 2
Germany
Hi everybody
I have a little problem with the CST VB.
I design a model in CST MWS. Know
I want to performe a Parameter-Sweep.
I choose a userdefined output.
Cause I want to analyze some data in matlab,
I want, what CST save for expample the energy in a ascii file.
A new file for every run of the sweep.
But this is not working.
Do you have a idea?
The code:
Option Explicit
Sub ParameterSweepWatch(action As Integer)
   'Please define actions for the parameter sweep watch here.
   Select Case action
      Case 0
      'Please define actions before the parametersweep starts.
      Case 1
      'Please define actions after each calculation.
       Dim zaehler       As Integer
       Dim Dateiname    As String
        Dim filename        As String
         Dim Fileendung    As String
         Dim strwert         As String
       Dim wertdouble     As Double
        wertdouble= ParameterSweep.GetValueOfVaryingParameter()
      strwert    = CStr(wertdouble)
      filename     = "I:\simulation-Output\File-"
      Fileendung    = ".txt"
      Dateiname    =
      SelectTreeItem ("1D Results\Energy\Energy [5]")
      With ASCIIExport
       .Reset
       .FileName (Dateiname)
       .Mode ("FixedNumber")
         .Execute
      End With
      Case 2
      'Please define actions after the parametersweep has finished.
   End Select
End Sub
Sub Main()
  ParameterSweepWatch 0
  ParameterSweepWatch 1
  ParameterSweepWatch 2
End Sub
Thanking for your in anticipation.
Added after 9 minutes:
I found the answer.
It was to easy!
' userdefined watch for parameter sweep
Option Explicit
	Select Case action
		Case 0
		Case 1
	     wertdouble		= ParameterSweep.GetValueOfVaryingParameter(0)
	     Parametername 	= ParameterSweep.GetNameOfVaryingParameter(0)
		Fileendung 	= ".txt"
		Dateiname 	=filename & Parametername & strwert & Fileendung
		With ASCIIExport
    	.Reset
		.Step(100)
   		.Execute
		End With
		Case 2
	End Select
End Sub
Sub Main()
End Sub
what is your problem?
you can get your results directly from file-export-ascii format
may that i understand from your question,if not forgive me for misunderstand
