Unforgiven
Newbie level 3
directivity vs frequency
Is it possible to plot directivity versus frequency in CST Microwave studio?
If yes then how?
Added after 34 minutes:
There's one solution:
to setup "single" farfield monitors at some frequency set and after simulation use Results->Template based postprocessing->1D results->Farfield (broadband)->
but this method requires setting up frequencies manually..
Trying to use "broadband" farfield monitor doesn't help - resulting plot is given only for one frequency set in the plot preferencies of broadband pattern in 2D/3D results.
Another trick is to use macros Farfield->Broadband Farfield monitors, but it results in a whole lot of "single" monitors, which is not so pretty solution...
Maybe somebody has another solution?
If yes then how?
