Hello.
I am working on some modifications of horn antennas in CST MWS 2006. I have 3 parameters or let's say 2.
I can use Par.sweep for one parameter and than change another manually, than combine results in MATLAB. It is annoying and take a lot of time
I run parameter sweep and set for example:
sequence1
x1=(50 100) (5)
x2=(50 100) (5)
Than I add postprocessing watch, 0D result.
(I am intrested in gain, sidelobe levels in pricipal planes, HPBW in principal planes).
CST MWS goes throw all wariables (5*5=25 cycles), but results are shown only for changing x1 Its not necessary to show results in CST MWS, it would be perfect if I can get ascii files with results.
I 've done something similar quite long time ago so I will only guide
you roughly and give you some ideas. Two options from me:
1) create a new folder within CST MWS results and paste there the required
graphs. Make sure though that these are relevant, e.g. I don't think of course that you ll be able to paste rad. patter together with S11!! or alternatively
2)save results individually in txt files by exporting them from MWS. Then use excel
to properly combine those results and produce a unified graph...
