sub main()
set_fr4
set_copper
set_vacuum
end sub
Public Function set_fr4
'define substrate FR-4 lossy
With Material
.Reset
.Name "FR-4 (lossy)"
.Folder ""
.FrqType "all"
.Type "Normal"
.SetMaterialUnit "GHz", "mm"
.Epsilon "4.3"
.Mue "1.0"
.Kappa "0.0"
.TanD "0.025"
.TanDFreq "10.0"
.TanDGiven "True"
.TanDModel "ConstTanD"
.KappaM "0.0"
.TanDM "0.0"
.TanDMFreq "0.0"
.TanDMGiven "False"
.TanDMModel "ConstKappa"
.DispModelEps "None"
.DispModelMue "None"
.DispersiveFittingSchemeEps "General 1st"
.DispersiveFittingSchemeMue "General 1st"
.UseGeneralDispersionEps "False"
.UseGeneralDispersionMue "False"
.Rho "0.0"
.ThermalType "Normal"
.ThermalConductivity "0.3"
.SetActiveMaterial "all"
.Colour "0.94", "0.82", "0.76"
.Wireframe "False"
.Transparency "0"
.Create
End With
End Function
Function set_copper
'define material: Copper (annealed)
With Material
.Reset
.Name "Copper (annealed)"
.Folder ""
.FrqType "static"
.Type "Normal"
.SetMaterialUnit "Hz", "mm"
.Epsilon "1"
.Mue "1.0"
.Kappa "5.8e+007"
.TanD "0.0"
.TanDFreq "0.0"
.TanDGiven "False"
.KappaM "0"
.TanDM "0.0"
.TanDMFreq "0.0"
.TanDMGiven "False"
.TanDMModel "ConstTanD"
.DispersiveFittingSchemeEps "1st Order"
.DispersiveFittingSchemeMue "1st Order"
.FrqType "all"
.Type "Lossy metal"
.Mue "1.0"
.Kappa "5.8e+007"
.Rho "8930.0"
.ThermalConductivity "401.0"
.HeatCapacity "0.39"
.MetabolicRate "0"
.BloodFlow "0"
.VoxelConvection "0"
.MechanicsType "Isotropic"
.YoungsModulus "120"
.PoissonsRatio "0.33"
.ThermalExpansionRate "17"
.Colour "1", "1", "0"
.Wireframe "False"
.Reflection "False"
.Allowoutline "True"
.Transparentoutline "False"
.Transparency "0"
.Create
End With
End Function
Function set_vacuum
'define vacuum
With Material
.Name "Vacuum"
.Colour "0.5", "0.8", "1"
.Wireframe "False"
.Reflection "False"
.Transparency "52"
.ChangeColour
End With
End Function
