Hey there,
I have several cst projects, each one using the same macro to build up for example a structure. The macro (the content from the main function) is then copied into the history list and run each time I hit "update" in the history list.
When I change the macro I have to copy the new content to the history entry of each project.
Now the question: Is there something like an "import" or "include" function I could use in the history list? With that I could easily change the structure macro for more than one project. (like: "include generate_strucure.bas")
Using search function I just found possibilities refering to objects called workbook or VBIDE among others, which is not helpful in the case of CST VBA, because as far as I can see there is no option to use that objects.
Thanks,
Rich
