Nov 16, 2016 #1 M myjae Junior Member level 2 Joined Sep 26, 2013 Messages 22 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,430 cst- how look at the impedance of distance ? cst- how look at the impedance of distance ? power voltage( 500V, 20A) source put into a long cooper bar then, other PCB plate sense a voltage level (according to distance 1mm~100mm) example ) when 500volt put into cooper bar, PCB plate sense 0.1Volt. so 1/5000 i quest) 1. how can source port give? 2. how see coupling level? 3. last, how can see impedance of distance i want to serch 50ohm distance .
