MSH said:You can find a CST tutorial about monopole in this below link:
I hope it helps.
regards,
aaron412 said:can someone please post the dipole example for cst, for some reason its missing from my instalation?? If anyone has had any experience simulating the sierpinski fractal antenna with cst please coment.........if you have a model please post......thanks...
aaron412 said:thanks eirp....those models would be a grat help, but im having problems opening the models.....I'm using cst version 4.2.....Could that be the problem?? is there any way to fix this....maybe save them in an old format or something.....thanks...
aaron412 said:EIRP, thank a lot!!! all of this is very helpfull!!, I have some questions regarding your model:
1- You used a wave port......, why?? it looks like you are trying to model a coax feed...am i right?? I was thinking of using a discrete port between the antenna and the ground plane ... would that work??
2- Tell me about the mesh generation...did you use adaptive mesh?? or some other option??
thanks again....
djtommy said:i'm wondering do u have some example or paper that show the characteristic impedance of the fractal antenna....
And if the antenna is designed as line edge feed... do it have some formula to calculate the line edge dimension?
