Register Log in
CST eigenmode solver accuracy problem!
wandering heart
Member level 5
Stockholm, Sweden
jdm aks eigenmode solver
I see in its manual, we should require more modes than needed to ensure accuracy, because solver may give poor accurary for higher order modes.
But one time, to confirm the convergency of results given by the solver, I increase the density of mesh step by step and inspect changes.
To some extent, I think the mesh is not very dense, just 900000+ cells, but even some lower modes have poor accuracy (marked with * by CST).
Anyone encountered such a situation? What's the reason?
Thank you for ur attention!
RFSimulator
Full Member level 3
Europe
aks eigenmode
which CST Eigenmode solver do you use? AKS or JD-Solver? If you are only interested in the first few modes ,I belive it is better to use the JD Solver.
F.
RFSimulator
Full Member level 3
Europe
aks solver
Hi
guess this no really a shortcoming. The JD Solver is just more robust as far as I know. The Playing around with the AKS Solver Parameters might also give you good results.
The JD Solver acaluates Mode after Mode. The calcualtion time goes up with the numbers of modes you need. THe AKS Solver calcualtes several modes is one shot. For a larger numbers of modes the AKS Solver is therefore much faster...
F.
wandering heart
Member level 5
Stockholm, Sweden
What do you mean by "playing around with the AKS Solver Parameters"? Which parameters can be adjusted to obtain better results?
On the other hand, the mode number I want is not large, just 5 or 6.
But now CST consumes 1.5-2 G Ram, and at last abnormally terminated.
I don't know why, maybe terminated by OS?
I heared Windows can handle at most 2G Ram, then what OS should be used for more complex simulations and bigger Ram?
Thank u all!
RFSimulator
Full Member level 3
Europe
Hi wandering heart,
in the solver special settings you find some parameters Like Estimation of the highgest eigenfrequncy e.g.. The default value is 0 if you do not not the higherst freq. Howver, if you alreday have a pretty good guess (maybe from some simulations before) you can enter this number there.
How large is your calculation in terms of mesh cells?)
Maybe you should send your structure to th CST hotline. DId you ever contact them?
F.
wandering heart
Member level 5
Stockholm, Sweden
Yes, I also see the parameter Estimation of the highgest eigenfrequncy.
I just gave a better estimation, solver is running now.
My model has more than 900M mesh cells.
You mean I can get help from CST homepage?
