winglj
Full Member level 4
reducing the pba fill limit
Hi, recently I am doing the simulation of patch antenna by using CST. But when I using the waveguide port for coaxial cable, there are some convergence problems arising:
The CST time-domain solver shows me the messege:
" The calcuation seems to be unstable! Consider reducing the value for the stability factor in the solver specials options or reduce the PBA fill limit in the automesh properties."
And the output signal will oscillate at the end of the simulation.
I am wondering how can I solve this problem without affect the accuracy?
It seems the output signal oscillation is due to numerical error. But what kind of setting will generate this type of errors?
And what's the meaning of the PBA fill limit? How can it affect the simulation/ mesh generation?
Thanks in advance, and any recomendations will be welcome.
