Hello,
I am moving the first step in EM simulation. As fist step I would like so simulate the current distribution on a simple PCB trace. I have imported the layout from ODB, then i have set the input and output ports. On the schematic windows I was able to obtain a realistic result. I have run an AC simulation with a 50 ohm resistor as load and the current result graph is consistent with the input voltage.
However, It seems that 3d view and schematic view are not consistent. I would like to change the resistor on the schematic view and see the variation in current distribution on the 3d view, is it possible ? currently they looks like 2 different environment, and it seems that schematic change are not reflected on 3d view. How can I solve this problem ?
Thanks
