Register Log in
Crystals voltage in UNO
vinodkaruvat
Hello friends,
I had a queer problem. I am just playing around with the arduino Uno board. Was testing the on board crystal(16MHz).
When powered up I can see that it gives a freq of 16MHz. But the peak to peak voltage is abt 200mV.
How is this possible ?
Arduino is 5V. SO it shld be min 5V, right ?
ANy clues pls ?
Vinod.
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
Three points:
1. It's an oscillator, it may not need full logic levels for the crystal part of it to work.
2. How did you measure the 200mV? You can only do it with a wide bandwidth oscilloscope and high impedance probe.
3. Are you sure whatever you used to measure it didn't load the signal down and make it smaller. The drive level to a quartz crystal is very small so drawing even a small amount of power from it will reduce the level.
Brian.
Toggle Sidebar
