crystal, EMI and capacitor
weeb0
Junior Member level 2
Hello,
I plan to use the mcp2515 ( can bus driver ) and I have to select an osc for it.
I have to use a crystal that have a frequency of over 40MHz. At that frequency, I'm scared about the EMI that I can cause.
What can I do to minimize EMI?
How to select the decoupling cap? ( is it the crystal load capacitance? )
The crystal I would like to use : https://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CTX656CT-ND
thank you a lot for your help
obinobi
Junior Member level 3
Poland
Hello
Did you want to use 40 MHz for some external bus clocking?
If yes you may add a RC on a clock net (but not on a oscilator) circuit to increase fall and rise time of clock signal. It will decrease higher harmonics of the clock signal.
Best regards
weeb0
Hello,
Thank you for your reply.
The crystal will be used only to clock 1 component. He will be placed very near of the component.
Thank you
obinobi
Poland
Hello
So you may implement shielding of clock net and oscillator. I mean ground plane under and copper plane nearby the crysta connected together through viasl. It's should be enough.
Best regards
