crystal controlled astable oscillator problem
efron
Junior Member level 2
Spain
Reactions: neazoi
    neazoi
neazoi
Advanced Member level 5
Greece
Yes, all I need is a 12MHz square wave oscillator using just transistors and crystal, not opamps
Tahmid
Silicon Valley, California, USA (from Dhaka, Bangl
Reactions: neazoi
    neazoi
efron
Spain
If you could limit the frequency to 10 MHz, Tahmid's proposal in his first or second link is a good and practical approach.
For higher frequencies, I can only suggest to use transistor-based XTAL oscillator with a very high gain at the amplifier stage, so that the output will be seen as a square signal because of the saturation of the transistor.
Would you know how to do that ?
Reactions: neazoi
    neazoi
neazoi
Greece
Thank you all for the schematics. Limiting the frequency to 10MHz sould be not much of a problem.
You see I have already tried to build one using inverters made out of transistors but it did not work...
But the original circuit from the author worked using 74HCxx and not 74LSxx and my gates were built using DTL and TTL
I have thought about the limiting amplifier solution you propose and this is of much interest but I cannot find any schematic on the web :( Maybe you could help a bit?
efron
Spain
I will come with a proposal in a couple of days as right now I have no spare time :-(
