Help wanted for CST problem
hi: I simulated a log-peroidic antenna with CST in these days. Maybe I can help you. However I only has CST 5.0. I cannot open your file. Can you convert it into a lower version. In CST5.0, one antenna project includes a lot of files, you need to upload all of them.
Do you compare this log-periodic antenna simulation with CST and with other sover, such as ADS momentum, HFSS. I found momentum has the similiar result. However, I could have a wide band simulation. It consumed a lot of memory.
