creating output file for printout
m_kavith
Member level 3
chennai
i created output using gerbertool. my problem drill holes are not opened in my pdf file. drill hole chart not required but it also comes in pdf file. i want to hide it.
what your tool? you can open or off layer and delete drill chart with gerber tools ex. CAM350 or CAMtastic in Altium or GerberTool in OrCAD for easy print out or you can use Blueprint software for create engineering document.
i use layoutplus and orcad gerbertool8.1.1.if i off the DRD layer i cant centre the drawing in printout and board outline is not visible.i attached one pdf. i dont need lik this
File-->page setup on Outline and Drill
if you need to print PDF data mens use any gerber viewer like GC PREVEUE which is free... then print to PDF. In many cases I have used this technique.
in my pagesetup there is no center option. i need pdf lik this.
